I have a 75 which I converted the front to disc brakes using 79 fj55 knuckles and OEM brake hardware. The problem is that I have to STAND on the brakes to stop. The brake booster is original but seems to be working since I notice a difference when I remove the vacuum line, even worse without vacuum to the booster. I also had to replace the master cylinder and I installed a new one from a 1991 4runner. I decided to use the 4runner master cylinder based on several postings by others who did the same. I also did not want to reroute brake lines and the 4runner Master was similar to the 1975 master which is much different than the 1976 disc compatible master. The rear brakes are the original drum brakes with rebuilt wheel cylinders. Do boosters go weak? How much vacuum should I have at the booster? Is the 4runner master undersized? Any other thoughts or help would be much appreciated.
