Alright I've read more than I can imagine the last 2 weeks on this issue. Tried many of the tips and help from what I've read. Issue still exists.
The two noticeable symptoms are cutting out on heavy acceleration, and a quick jerk while at stop lights or at a stop/not rolling or accelerating (like just in my drieway or parking lot) and rpm drop of only 100 or so rpm very quickly when it's in drive or reverse. The rpm drop is very quick, drops for a millisecond and right back to normal rpm. It's almost a jerk, entire truck shakes but it's very quick. And it will do it randomly. No consistency to it and might go 1 or 2 minutes without doing it at all, but then it might do it 4 or 5 times in 20 seconds. In park or neutral it does not it at all. Idles perfect. So far I've done this list of stuff.
Spark plugs
Plug Wires
Distributor cap
Rotor
Fuel filter
Found couple vacuum hoses off (someone said it likely clogged my catalytic converter??)
Cleaned butterfly valve
seafoam in gas tank and vacuum line at brake booster.
Spark plugs
Plug Wires
Distributor cap
Rotor
Fuel filter
