Stop speed???? (1 Viewer)
Charleston, SC
What is the top speed of the 2F in our Pig?
WHY CAN'T WE EVER EDIT THE TITLE!!!!!????
Heh. I doubt it's much past 65, but I know the stop speed is 0 mph.
I have no idea what the tach would read at 65 without having one!!! LOL
Mine will go 100km/h, or just a smudge over. But seems most comfortable at 90 km/h.
I'm interested what size tyres people have too. I'm tempted to go up in tyre size, to 33's just go get a better top end speed, I know it will be a little moe sluggish down low, and I'll loose a bit of gearing. But it's a pretty low 1st
85 MPH sustained without adverse affects. the inside lane is an odd place for a freeway pig to be...2F with dual exhaust and a cam, 4 speed, 4.10s on 285/75/16s. I had alot of room under that pedal, and at least another known grand of engine speed to spare...
I read the 2F made max power @3800 RPM
in our Pig
I’m guessing pushing a pig through the wind at speed is going to take all the 2F HP so theoretical top speed should be around the 3800 RPM mark.
If you’re running a 4 speed, 4.10s on (33”ish) 285/75/16s like LAMBCRUSHER then 91 MPH@3800 RPM
If you’re running 4 speed, 4.10s on 31” tires then 86MPH@3800 RPM.
I have no idea of the 2F’s ability to run at sustained MAX RPM but if it will run safely @3800 RPM then it should have no problem cruising the max speed limit in most states.
According to Toyota, 85 MPH "all day long".
Of course, this is while transporting "7 husky men"
I've done a lot of all day cruising at 70 in 40's and 55's, hitting 75 to pass easily and cruise for short periods, 80 on occasion. Pending the memory factor I think 80 was around 3600.
Up hill changes things, steep hills all bets are off. Stock engine and tires.
65 without the Fairey OD. With the OD 75 is not a problem. I like to keep the RPM's around 2,700. Higher than that and I'll have to replace the radio so I can get more volume.
