Stock wheels wanted
Houston, TX
I am looking for a set of stock wheels and hubs for my 73 to replace the blingy cheap cutlass rims the PO had on this thing. I am in the greater Atlanta area. Shipping is a possibility. I will be painting the wheels back to stock color. Thanks.
Heather I think you can get the hub caps from Rick. If not they are on E-bay new for $100.
Rims are a different story. Though I think they are still available might be $$$
oem wheels
I checked with Cruiserparts.net. They told me:
The used rims needing a sandblast and repaint are $45 each. + $19 each shipping.
The new rims are $99 each + $19 each shipping.
If this still has the drum brakes there are probably folks out there who will give you the rims to fit a drum brake (I've got four but they are in Guatemala!). If it has been converted to disc or you are planning to then you need the more desirable disc brake rims.
Heather, been following your efforts so similar to mine........I put 16 inch OEMs out of a Tacoma/Tundra on our FJ 60 and have been very happy with the improvement in milage am planning to do the same for our pig.......believe the bolt pattern is the same................16 inchers out of a wrecked taco/tundra are plentiful and cheep and can be found with decent tires...........mine had less that 500 miles on them!
Lou
Got the wheels!
Thanks ya'll for your comments and suggestions. I am staying with drums as of now, so the older rims will work fine.
A big thanks to Buckethead who has these available and is willing to let me have 'em!
I am all set on the wheels. I have a line on the caps too. Now I just have to find some hubs...
Do you still need "hubs"? I just got a 69 and 71 and am putting 1 tons under one of them. Are you refering to lock outs or the actual hub/spindle set up? LEt me know.
PMed ya on the hubs
