I have 24v so two batteries in serie and the winch is a big wack in voltage (like glow sytem and starting)
So when in use it drops to or below 12v (per battery, so 24v) and I rather leave the engine running but the alternator is a new old stock 25 amp so that thing does not do much.
Here is shows a bit how much amps are chewed when the winch has to work:
12V DC PERFORMANCE SPECS
Line Pull
Lbs.(Kgs.) Line Speed
FT./min(M/min.) Motor
Current Pull by layer
layer/Lbs(Kgs.)
0 30(9.14) 67 amps 1/12000(5443)
2000(910) 14(4.27) 140 amps 2/11120(5044)
4000(1810) 8.62(2.63) 210 amps 3/10340(4690)
6000(2720) 6.92(2.11) 250 amps 4/9770(4432)
8000(3630) 5.80(1.77) 320 amps 5/9250(4196)
10000(4540) 4.39(1.34) 370 amps
12000(5440) 3.86(1.18) 440 amps
24V DC PERFORMANCE SPECS
Line Pull
layer/Lbs(Kgs.)
0 31.94(9.57) 24 amps 1/12000(5443)
2000(910) 11.7(3.57) 105 amps 2/11120(5044)
4000(1810) 9.5(2.90) 129 amps 3/10340(4690)
6000(2720) 8.5(2.59) 152 amps 4/9770(4432)
8000(3630) 7.5(2.29) 175 amps 5/9250(4196)
10000(4540) 6.5(1.98) 198 amps
12000(5440) 6.0(1.83) 221 amps
Above performance specs are based on first layer of drum
don't use the old solenoids (can go sticky, add power cut off key)
Albright Contactor - Extra Duty is safe
Below dash voltage is not heavy use, but it tries to destroy the battery and you also want to start later.
A 12-volt battery typically operates within a voltage range of 12.0 to 12.8 volts when fully charged and can be considered fully depleted when it falls below 11.8 volts.
- Voltage range when fully charged: 12.6 to 12.8 volts
- Voltage range for normal operation: 12.0 to 12.5 volts
- Voltage level indicating discharge: Below 12.0 volts
- Critical undervoltage threshold: 11.8 volts
- Risks of operating below critical threshold: Battery damage and reduced lifespan
