STLCA 60 Series Club Thread (4 Viewers)
ok...so I cut and drilled my parts and got my friend to do a little welding, then took one of those 3M scotch-brite type pads and roughed the metal up a tad, then spray bombed them black....heres how you know you have a problem...when you drag your fat @$$ under the truck on the drive-way and install them in the dark while laying on your back on the ground.
So I used 2inch flat bar for the base and I replicated the 4.25 inch center to center bolt hole on lengths about 5.25 long. Then while over at my friends I robbed a couple sections of 3inch square "tubing" which I cut down to make it about 1.25 tall (think two sections of C channel), somewhat in the style of the picture above. I used daystar KU09014BK single stud bump stops that are approx 3inches tall, by 4.5 long * 2.5 wide.
I was determined to get them on there this evening before the forecasted rain here tomorrow. I did have some concern with making these things too tall, I guess we'll see how it goes, I think daystar or energy has another bump stop of similar design but about 2inches tall. I had to give it enough room to accommodate the single stud mount, but I guess I could have cut that down a little if I would have been motivated. We'll see how it goes and I can learn and modify from there if what I made needs changing.
Normally I don't plug stuff from wal mart but I bought a cheapo battery powered LED light from there a few weeks ago and it works well, puts out a lot of light and its larger than the little pen light things...and it will not burn you and has a magnet made into the body for mounting, its in the style of a shop light. Get one..it will reduce your use of profanity..:)
I'll post a pic up later...These bump stops appear to me to be progressive...so I'm not too concerned about intial contact with the axle...I did not get a good look this evening...but feel free to post up comments if you think something could be improved or changed. Basically as noted I'm just wanting to control wheel upward travel into the wheelweel...just trying to reduce that travel a little bit or limit it to some degree.
http://www.amazon.com/Daystar-KU09014BK-Single-Competition-Style/dp/B004IARR9A
Can't wait to slap this bad boy on
@sk8salomon would you or @Elbert measure the hood prop on the 60 next time you have the hood up, please? I have a hood prop from something, a mini truck I think, but was curious about the length as I know a lot of 80 guys have installed a 60 hood prop on the 80 when their struts give out and was wondering if this one is long enough or if it should go in the scrap pile.
Thanks in advance
Thanks in advance
I can but I will not be home until next weekend.
Thanks in advance
33" from pivot point to bottom of hood
Thank ya Sir. I think I can make it work. Mine measures 32.25" from center of pivot to where the hood would sit.
@jynx I got one the other day at pull a part off of a 60 and it was too long for my 80. I have a 4R hood prop on my 80 now, but just couldn't pass the one up that was on the 60. It could be cut down and bent and made work pretty easy though.
Good find, looks like you are getting ready for GSMTR 15 !!!!
Any time is good. Was thinking about price, no charge sk8. FREE
Still looking for a good used windshield so I can get my cowling in the right place before welding it back on.
removal of rear heater....anyone removed their rear heater from under the driver seat...what did you use to block the holes? specific reference to plugs or strategy....all else fails ...might get friend to crank up mig welder...
