- Thread starter
- #21
The chain brake on an 030 were a disengaging clutch system. There is one little curved spring that makes the system work that is attached to the clutch. The system works great but after 40 years parts are really hard to find.
The 032 is an easy repair for the chain brake. It is the entire side cover assy. If you saw did not come with it originally (it should have in the USA) you may have to change out the hand guard. The hand guard is the black piece of plastic that mounts to the handle frame. The Chain Brake style hand guard has a modified pivot area where the screw and tension spring hold it to the handle housing. This allows the hand guard to move all the way forward or down so the chain brake can engage.
Post up a picture of what you have, I will tell you what you are missing.
