Guys I need some help/advice. Yes I have read just about every steering post on here. Reason for posting is my problem remains even with a brand new rack which is the usual suggestion. The following are my symptoms and what I've done so far. Also some backstory...
Backstory:
Took my 2003 Lx470 to a reputable (I thought) local land cruiser shop to have it looked over. One of the items mentioned was my steering rack was not centered. I had them center it. As soon as they centered it the steering became very stiff. They claimed it was coincidence and that I should replace the rack, UGH. Not sure what happened or why centering the rack would break it. Maybe a seal blew or something, I don't know.
I tried a VRGS re-centering, multiple alignments. Nothing helped.
The stiff steering is much worse at slow speeds when parking but still quite noticeable at high speeds.
Symptoms:
Stiff steering at low speeds
NO VGRS light, has been zeroed and everything by both me and a lexus dealership
No noise or whine from power steering pump, or leak.
Parts I've replaced:
Per the shops recommendation I replaced the steering rack with a brand new Toyota rack (no change in steering, still stiff)
New in and out hoses and new reservoir
New Dexron ATF used
At this point I'm planning on doing the power steering pump as I'm not sure what else could be causing this. Any help is appreciated!
Backstory:
Symptoms:
New Dexron ATF used
