Stereo install - Capacitor? (1 Viewer)
Stereo New
Rob Faucett
GOLD Star
Seattle, WA
Dudes - Got the stereo installed and it works great. I like what I bought. Pioneer DMH-WT7600NEX and Pyle 6.0 Farad Digital Power Capacitor, dual battery setup (not sure this matters).
PROBLEM - Stereo reboots when the engine is started. Pain in the ASS given what I use the truck for.
SOLUTION - Attached the capacitor to the "constant power"/yellow wire of the stereo.
Any ideas on why this doesn't solve the problem?
Always appreciate your help!!
Thanks,
Rob
Capacitor reads 12+V.
When the IGN (typically red) lead has power cut by switching off your truck (or the typical circuits that cut power as the engine is cranked), it'll witch off the stereo.
Solution is to have a constant hot lead running through a fuse and switch to the radio's IGN lead. This way when you shut down the truck you can manually switch off the radio, and it'll still stay on during engine cranking. Be careful though, if the constant hot on the radio goes to too low of a voltage when cranking, the unit will switch off (and then back on once voltage is restored) regardless of whether the IGN lead is switched on or not.
This video shows how to wire a small capacitor to your stereo to stop it from switching off during cranking. I had a similar issue with a pioneer stereo my FJ 60. Once I wired this up never a problem again. Its also smaller then a AA battery so tucks nicely up under the dash.
Please explain exactly how you wired your stereo there is no need for that big ass capacitor you only need one that big in a large car audio system and it goes incline with the power cables to the amplifier/ amplifiers.
This is the answer to my particular issue. And, in short, I'm just going to live with the issue for now. I have Stereo Red - Ignition Switch power (see above for wire designation; Stereo/wiring help? - https://forum.ih8mud.com/threads/stereo-wiring-help.1365172/#post-16011846). Black to ground and yellow directly to battery (+). As @Spook50 describes my specific issue is a reuslt of how the ignition swithc actuall works. Capacitor is not a solution to my problem. Always helps to know what you're doing. Something I have no experience with! Thanks very much for your help. @Spook50 nailed it. Really appreciate it! Off we go to the next issue . . .
