Yes there's a way. Go to the top of the page, and click on "thread tools" and you can figure it out from there.Is there a way to "watch" a thread like this one without posting on it to make it easier to find in the future?
Lack of return-to-center could be lack of caster (or other alignment issues). You should get it professionally aligned. Also, your knuckles should easily swivel back and forth after your knuckle rebuild (you'll have to pull the TRE at each end to get a good sense).
Steering box adjustment: With the truck wheels pointing straight ahead, have a buddy gently saw the steering wheel back and forth while you watch the steering box. If there is a delay (play) between the input shaft movement and output shaft (Pitman arm shaft) movement, you have some play in your box. Search some threads, and gently/delicately adjust your box and test drive it. Do not hork down on the adjustment screw, and remember that most box wear is in the 'straight ahead' position, so if you remove ALL play in the straight-ahead position, your steering box WILL likely bind at the full-turn positions (left or right). Be judicious about this and find a happy medium.
My FJ62 with 256K miles has all the tightness/lack of slop I would expect to see in a well-functioning recirc-ball steering system, and the PS box has not been rebuilt - just carefully adjusted. I have new TREs, but all else is original. It will never feel like rack and pinion, but should not have huge play and no return-to-center.
Bald or wide tires, or ones that are grossly overinflated, can cause poor handling. From what I read, West Texas Offroad is the place to get a steering box rebuilt at a reasonable price. Sounds like you have dialed in the steering box adjustment, so that's good.
It still needs a lot of input from me to maintain a straight line - this makes me wonder about your toe-in, and if the alignment was done correctly, but if the steering box is sketchy, maybe get that addressed first. Did your alignment shop provide a print-out of camber, caster, and toe? (they rarely do, unless you ask).
They are made from cast aluminum and they brakeHey lovetoski, what's the issue with aluminum ones? I've got a set that I've been meaning to put on, though i did have some worries about dissimilar metal corrosion. Is that the problem?
