Steering rack bushing replacement? How easy DIY?? (2 Viewers)
Atlanta, GA
Trust me, I searched first with minimal success. Can someone tell me how easy it is to replace the steering rack bushings on an LC or send the link to a previous post? Mine has a funny pull to the left... 321k, pavement princess but pulls my boat a lot. Dealer realigned it but no change... brought it home, pulled the drivers side front wheel and sure enough if you moved the wheel the steering rack would lift noticeably. Passenger side not so much if any. The rack isn't leaking so no need to pull it. Didn't pull the skid plates for a deeper look yet.
Any advice on replacement parts much appreciated !!!
I ordered poly bushings since that’s our only option (or was at the time I replaced mine a few years ago). This was one of my first jobs I did on my 100 and it wasn’t difficult other than having to lay on the ground for a while. The most frustrating part was one bolt had like two threads exposed so blindly attempting to put the nut on was a b****!
Do they not produce OEM bushing for the steering rack? I'm looking to replace mine and I'm a little skeptical of using poly urethane.
Only way to get the OEM bushings is to buy the whole rack. With the polys your steering will feel a little tighter and you’ll feel a bit more road vibration. I wonder if you can drill small holes in the poly bushings for more give??
I used poly bushings and did this job right before I sold my truck earlier this year. The job is not exactly fun. It's very doable but takes some patience to get the factory sleeves out after you rip the bushings out. Lots of prying the rack forward to get the right angle on the rack to push the sleeves out.
My shop replaced my bushings with poly bushings, brand unknown, and they allowed the steering rack to slip. I gave them White Line bushings and it held securely.
Id put whiteline bushings on if you have no intentions of replacing the rack. I had bad bushings and went ahead and got a whole new rack since mine had some small leaks and I don't intend on ever selling it so why not just do the refresh. Id also get outer tie rods while you are at it since if your bushings are shot and your tie rods haven't been replaced, they likely could use the refresh. Whiteline you can avoid pulling the rack to install polys. As others have mentioned if you are an OEM freak like me, It would need a new rack
Unfortunately I already purchased Nolathane bushings, but from what I've read online they're a sister company of Whiteline. Plan on swapping them this weekend.
How have your polyurethane bushings held up? Any slippage?
I installed Whiteline several years ago, to buy me some time before replacing the rack, as I had a leak as well.
It seems the Whiteline bushings and some AT-205 have given me far more time than I expected.
If you aren't replacing the rack, you can be confident the Whiteline bushings will hold up for at least several years (5ish)
