I'll get an apt. w/ Slee in 2 weeks and hopefully they can figure it out, if I cannot by then!
Skid plate? This thing came with skid plates? Yup, definitely missing those...AND GET THIS! The small Flywheel cover at the bottom of the bell housing is missing. I'm guessing it was not installed after they rebuilt the tranny 1.5 YEARS AGO! It's just a giant opening facing the front of the vehicle. Flywheel is spinning away in there...who knows what's inside that bell housing
I am throwing a P0715 Code...I replaced the tranny input shaft speed sensor and that didn't fix the MIL light...I'm guessing due to no cover, something has been damaged in there.
Awesome!
This free LX thing is now looking too good to be true! I knew this car has been abused as a farm truck for 15 years, but it was a single owner and always serviced at Toyota for 255k miles. I was hoping for better. The engine and tranny were rebuilt by Tejas Toyota in Houston...who the heck do they have working on these cars!
Did I mention it was short on coolant, so I filled that up yesterday with Toyota Red and it's now leaking out of God knows where?!?! (somewhere below exhaust bank on drivers side, above the AC compressor) Too tight in there with the shock towers covering the leak, so can't see where it's coming from...but I can see that the exhaust heat shield is not bolted down...just hangout out. It's a tight fit, so I can't pull it out. Guess I'll need to source bolts for that.
@2001LC, you were right. The steering rack is sliding back and forth in the D bushing...I'll get those ordered and installed asap.
I got around to measuring the snap ring gap....It looks like I could use a 2.8-3mm thick snap ring. There is approx. 1mm of play between the snap ring and outer axle teeth. This is on the same side where someone used a screwdriver and hammer to tighten the axle bearing load nut. I had to file off the burrs to fit my socket over them. The grease in this axle is brown and soupy leading me to thinking they have combined non-compatible greases...I'll start with the thicker snap ring to try and diagnose the VSC. I'll get around to tearing into the axles once I can diagnose this VSC. If the VSC braking issue can't be fixed, I'm selling this frieebie. I'm not going to get in too deep on a 255k mile LX470 that's been beat up!
For the record, I have another thread going on my issues...It has a lot more back story on this particular LX. I resurrected this thread in hopes of finding techstream help.
I am throwing a P0715 Code...I replaced the tranny input shaft speed sensor and that didn't fix the MIL light...I'm guessing due to no cover, something has been damaged in there. Awesome!
