hmm, i just have one small single wire going from the (+) into a big round connector and that going into another round connector. how do i know if the cable is working?
Its this on an 83 FJ60.
ive looked at all the wires, everything looks good. if a wire is blown, it will be clearly visible right? or does the connector needs to be taken apart ?
i don't understand some thing here ,,,,,,,, it will start and run " with choke on" but won't stay running if choke is off ....... what can a fuseable link have to do with it??? we are talking about air/fuel mixture in a carbed engine,,,,,,,,,choke air and it runs ..... release choked air and it stalls h'mmmmm vacume leak or fuel cut off switch ........
Is there any fuel when you look throught the window in the carb? You may have a stuck float.
If not, when it's running on choke, tap the cab with a screw driver. It may unseat or unstick the float.
Dan called it waaay back... I'm stickin w/ old Beagle-boy, just as I had before.
Somewhere the carb is varnished due to the at least 6 mo. old go juice.
had some time and checked the fcs, its definitely clicking, so i dont think its the fcs. it seems to run at over 1500 rpm with the choke on the 1,2 setting, sputters with the choke off and dies. im thinking the carb needs a rebuild.
whats an ABV?
one thing i overlooked is the old gas, its almost empty too... ill fill it with 5 gallons of new petrol and see if that helps.
