Yes. Looks good. Did you get the carb idle problem fixed ?
one thing i actually forgot to do is warm the engine up. i did the test early in the morning. i think those number would improve if i actually warmed the engine up first.
still trying to figure out where the vacuum leak is by squirting carb cleaner on vacuum hoses.
remember to do a search for hoses when it comes time to replace yours. I got some from McMaster Carr couple years back when i redid all the hoses on my 87. Probably going to do the same on the 84 when i desmog.
So Fusible link didn't help and you have tried some carb cleaner/seafoam - still doing it? (just in case).
GL!
rob
i tested the fusible link, it seems fine. i did spray some carb cleaner down the carb etc. how would seafoam help? just dump it in the carb to clean it?
