My 08 has 265k miles on what I believe is the original starter. I generally pay close attention to the truck, keep up on maintenance, etc. and have had very few issues that weren't easily resolved.
I have been considering replacing the starter preemptively, as that is one failure that is somewhat likely and certainly would be inconvenient 2000 miles from home. When shopping starters on any of the common Toyota parts sites (Bosch, Camelback, Olathe, etc) I noticed two things:
1) The factory starter has come down in price significantly, and can be had for reasonable money (~$186 right now) which is less than most auto parts stores questionable reman offerings.
2) The solenoid only is available as an option for ~$54
I noted in several threads that folks removed the solenoid from the original starter to facilitate easier removal. This would lead me to believe that a solenoid only replacement on the trail might be relatively straight forward if needed, certainly easier than replacing the whole starter.
That leads me to the question of whether the newer solenoid on offer from Toyota (which I assume is for the most recent smaller starter) will work with my factory starter, can anyone confirm?
If it was fairly certain that the $50 solenoid would fit my factory starter, I'm thinking of buying the $50 solenoid for my trail box just in case. I have read up on the long screwdriver trick, but If I were on a 2 week trip, I'd rather replace the solenoid in the field and keep moving. Then when I get home I could replace the whole unit.
