2010 lx570 spare tire question
My spare tire winch seems to be a little tight and when the tire is all the way up it rocks a little. Is that rocking due to the spring on the winch assembly or is it supposed to do that?
No, tire should be immobile when it's fully winched up. You probably need to crank it a little more. I usually spray silicone lube all in and around the winch and chain every time I use it to keep it moving smoothly.
Ok. I'll check into that. Thank you
