I didn't find anything in search that matched.
Here's the problem, it's been going on for a while, but it's more frequent now.
On occasion the engine stalls out immediately after turning over. This can be mitigated by applying a little throttle and holding the engine at about 1k RPM for 10 seconds or so, then letting off and it goes to normal idle.
In the event the engine stalls out the headlights dim, sometimes the battery discharge light comes on.
It never stalls after the engine has achieved a stable idle, and doesn't stall when you put it in drive or reverse.
From time-to-time the battery discharge light will come on while driving, temporarily.
Battery is brand new, K&N air filter is cleaned and recharged in the last year. Mechanic performed a battery and alternator check last week, both turned up ok, and the problem couldn't be replicated in the shop.
Thoughts? Anything jump out at you, or I can check?
