Spring over VS spring under- pros and cons- Toyota Sunrader RV
I know this isnt real hardcore but I wanted to put this in an area where more people are doing other things than just simple lift kits etc.
I could have posted int he 60 or 40 series section since they are spring under but this is for a mini truck so I figured here would be a good place for a question like this.
I am putting an FJ80 axle under a Toyota Sunrader RV (pic in the Expedition builds and 79-95 section) the question I have is what are the advantages and disadvantages to using spring under other than the obvious of ground clearance?
I have seen older toyota desert trucks use spring under for racing for whatever reason and I do realize you need more arch to put the axle on the topside of the springs to get the same amount of lift- would it be advantageous for me to do it this way and why?
I am wanting this to be as roadworthy as I can and have some offroad capabilty but stability, and handling are my first priority here.
thanks for any input you may have
