that is what bfg called a rim protector. the point was to rub that edge before the edge of your rim. they are crap for off road though. i know i'm not the only one who had issues when aired down of them "scooping" crap inbetween the rim and tire bead and causing air loss. happend to me three times on snow runs when i'd start hearing the air leak, rush to get to a flat spot to change my "bad" tire only to get the tire hot enough to melt a piece of ice/snow out and have the leak stop.
haven't run bfgs since that horrible experience. always liked them from an economy/daily driver point of view before that.
btw, thanks from a two pair of split rims owner for the awesome pictoral.
I see now that they actually have the words "rim protector" (in small lettering) printed on those bits of the casing.
And I find it interesting/helpful to hear your experience here Nuclearlemon.
At least that KM tyre is only my spare and the KM2s (on all my other wheels) don't have rim protectors. (BTW ...With that magnificent "tyrepliers" tool I just bought, the rim protector didn't hinder breaking-the-bead anywhere near as much as I thought it might.)
Regardless of the "rim protector feature", I've learnt that if anyone mentions almost any tyre brand, news of "bad experiences" seem to appear.
So I'll stick with BFGs (for the timebeing at least).
Don't you just love the look and smell of new tires!
Yep!
And there's little else you can do to your vehicle that has as much effect as changing your tyres. (Both in appearance and handling/performance.)
The tires (spelt the American way by me here for once
) look a little skinny to my eye in this photo. (But nevertheless, I'm happy enough!) ....
I believe the main purposes of the liner/flap are to: (1) prevent abrasion of the tube (if the rim or lock ring are rusty or burred), (2) prevent the tube from being forced up into the valve stem slot in the rim where it will eventually split or be cut.
You have cancelled out these concerns by keeping your rims smooth and clean and by using a washer around the stem. Looks like your washer was cut from an old tube and is the reinforced section around the stem.
In my opinion, a multi-piece tube type assembly is easier to breakdown and reassemble than a drop center tubeless rim. That is assuming the wheel and lock ring are free from rust, damage (and wet paint JohnnyC).
Seeing this reminds me of when I was in my 20's and working on larger versions of this wheel every day. Makes me wish I had a set for my '79 FJ-40.
Well done.
Regards
Jim
Thanks Jim.
I think I've got it all sorted pretty well now too. But that's not to say I couldn't have done better....
I often tend to go back over work I've done in my mind and reconsider things. And I must say I'm wary of my use of "lots of silicone spray" in the assembly this time round.
I now fear spinning my wheels inside my tyres especially since those new "tyrepliers" made it seem so easy to "break-the-bead" on my spare (the KM tyre) which had silicone used on its bead more than 3 years ago (back in March 2007).
I think I'll have to make sure I don't do any serious off-roading for a few months at least (and even then keep my fingers crossed)! No problem though ...I've got plenty of other things waiting to occupy my time beside off-roading at present.)
Perhaps if I'd sprinkled talcum powder inside the casings and then vacuumed up the excess .... as well as ...shaking the new tubes around in bag filled with talcum powder...and used soapy water sparingly on the beads ......... I may have been better off
I think my reluctance to use soapy water stems from the days when my rims weren't hot-dipped (and my fear of rust) .... And if there isn't any excess powder - I don't think it would tend to "clump" when water infiltrates. (And I know soapy water doesn't retain its lubricating effect for long.)
PS. I've edited a previous post in which I said I thought one of my plastic washers had damaged a tube. Closer examination showed that that tube was along way off failing because the tube was in fact heavily reinforced there (near the valve stem). Nevertheless, I've rounded the edges of all those washers that I had previously neglected in this respect. (So the ONLY cause of real tube-damage that I've found here is actually restricted to "sticker damage" ...and that damage was widespread amongst all wheels that have seen any significant mileage.)
And my washers are actually made from a very soft plastic (and not from other tubes). This plastic was actually sold as "4x4 mudflaps". But while the plastic was ideally-soft for my use here it was actually a bit too stiff for use in mudflaps. (Hence I use thick/heavy "real rubber" instead as my rear mudflaps.)
