Hi everyone,
I need a little help. I'm in the process of converting this 66 axle off of my 45 project from drum to disc brake so I figured since I'm pulling the axle shafts out I might as well put new seals and bearings while I'm there. When I loosened the bolt for the spider gear shaft and it dropped down I heard a cling as if something fell. It was the curved spacer that I quickly fished out. I then rotated the whole axle to drain out the gear oil and something else fell out into the oil I was draining. It is a round flat shim about the size of a half dollar. I guessing since it has the same ID as the spider shaft that it goes somewhere with it. What I can't figure out is exactly where? I looked at several drawings of the differential, but I don't see that thing anywhere. It did say "this side up" on it. Any help is always appreciated.
thanx,
Craig
thanx,
Craig
