- Joined
- Dec 2, 2014
- Threads
- 17
- Messages
- 4,004
The Yellow Box plug-n-play harness connects to the output of the transfer case, and that IMO is a much easier option of removing the glovebox and splicing wires. This is upstream of the engine/tranny ECU, so it thinks nothing has changed. The RPM shift points would be the same, only the speed would be different.
I had the YB PnP on my 80 and it worked very well and was simple to install.
Thanks for the input.
I get the part about the P-N-P directly off of the transfer case, and that is "upstream" of everything.
From my perspective and/or background
"Method 2's splicing"
dropping the glovebox
cutting, soldering and shrink wrapping a few wires
reinstalling the glovebox
drop the yellow box in the glovebox.
seems a whole lot easier (and more appealing) than
"Method 1's P-N-P"
climbing under the vehicle
finding the right plug
inserting the P-N-P harness
Identifying a suitable grommet to route it back to the interior (or waterproof it find a place to mount it under the truck)
routing and zip-tie the cable
peal back the interior to find the grommet on the inside
route the cable to a suitable spot in the interior that allows initial adjustment and tucks out of the way when done.
Digging through the forum, I see a number of write-ups of the "splice and dice method": finding the right plug
Installing Generic Marks4WD speed calibrator that uses pin 6 on IX1
Installed a superlift speed sensor calibrator that uses pin 7 on IX1
I'm just trying to wrap my head around what is "upstream"/"downstream" of these points (what systems would receive the modified signal), and do I want to modify the signal on pin 6 or pin 7...
