speedo gear install question - solved
Austin, TX
My speedo hasn't worked for a bit and I'm finally replacing the cable. I had to remove the speedo gear from the tcase to get room to unscrew the seized cable. I am trying to re-install and simply can't get that gear to go back into the case. Do I need more patience and just find the perfect point where the speedo gear slides / meshes into the tcase gear? Or is there some other trick? Thanks!
