To give parts numbers of Toyota direct replacements here would be confusing, as they are year dependent in many cases.
Sometimes cutting our lengthens of a hose makes senses.
Toyota sell 2' lengths #90999-92003 that are cheaper by the foot than 3' lengths #90999-92004 of the small vacuum lines. Possibly they sell that one larger diameter in lengths as well IDK. They fit perfect and are marked as replacements, which is nice.
Some hoses vacuum, fuel, coolant, transmission, steering I buy that are the Toyota OEM direct replacement, get very pricey. But most found at auto parts store either aren't a good fitment (SAE as opposed to Metric), not they quality of Toyota brand or wall thickness is different (thinner). But one like the 98-02 power steering return line, is not available from Toyota separately, so alternative must be found.
Here is one example of a vacuum hose assembly I'm now finding bad in most rigs. In some they are still "ok" but are going bad, so most be watched. Other's they are leaking now and must be replaced. This is the assembly coming off the power steering van pump. These have a number of bends, housings/covers and clips that makes pay the price worth just replacing with direct. There is at least three different part numbers depending on year, for this one. Main reason is we have different throttle bodies, second we have different intake manifolds, third we have different steering rack which may mean different van pumps IDK.
06-07 van pump hose assembly. I've just order two set of this one. Last time it took three weeks to get. I did just get word, they'll be in this time in 5 business days from order date.
Notice cracking of these at van pump. This is from The Black Knight 06 LC with very low mileage, supper clean rig. They're not currently leaking, but may if removed even once. Stages I see are: stiffness, cracking, shrinkage (loose). Stiffness is when I put on watch list. Cracking schedule replacement at next service interval as a PM. Shrinkage and they are not serviceable and must be replaced.
Some hose have very tight bends that a cutting lengthen of hose just can't make. Or hose has some clip or hosing that it's just better to go with OEM direct replacement.
