Folks, I'm having some trouble with my ignition on a pre 75 FJ40 like vehicle. First let me say I've converted my points to a pertronix kit.(I realize this may be the problem)
So, I had a hard time starting the vehicle the other day. My ignition stuff is in fairly decent shape new plugs, cap and rotor and less than 10k on the plugs wires and coil. It fired at first but, stalled when I left it to warm up and I couldn't get it restarted. My only thought is I have a universal ignition key switch and when I turned off the key the engine bumped?? I figure it's the switch so I grabbed another one and that's not it. It still bumps the starter.
I changed the coil wire and later that day it started up. After 2 days sitting I decide to take it to work. She fired right up, all is well 1/2 way to work (10 mins) The engine cuts out dead not even trying to run. I notice when I crank it the tach is not spinning, So I grab the the wire and coil wire, give them all a jiggle thinking this is where the problem is. My "new" coil wire is a bit on the short side, thinking the engine torquing is stressing the the wire. And it worked and I drove another 300 yrds and it happened again, played again and drove it home. I have been unable to get it started since the. I put on new wires and a new coil.
Best I can tell I have 12v to the coil(internal resistance coil) I'm not getting any spark from the plugs.. I'm thinking it's the pertronix.. but why doesn't the tach work?? It's connected to the neg- post on the coil and it's ben there for over a year now. Should the tach crank with the starter??
any thoughts or help would be appreciated..
bob
bob
