Spare tire solution - after upsizing my OEM tires (8 Viewers)
You can also get a tire carrier for the tailgate. Or strap it down inside. That’s another option.
The only problem about strapping it inside is it kills your space when Costco shopping!!! :D
Some kind of swingout carrier is the ideal long term solution, but they're all expensive and come with their own tradeoffs. I'm looking into the various hitch carriers and they're almost the same price as custom/aftermarket steel bumpers. The tailgate carriers like JW Offroad are a neat idea but I'm concerned with longterm effects of drilling through the tailgate and hanging 80+ pounds off it. They all need some modification for backup camera and parking sensors as well.
I'd rather run a smaller tire than run snow chains on a tire.
How much room do you need? If it's a tight fit a combination of the KDSS spacers and deflating the tires might get you enough room to clear. Just carry a compressor with you to re-inflate when you need it. I've fit 265/65/18 in the spare area, it's tight but doable so I think you'd be able to squeeze 276/65 if you let the air out.
What I want to know is, has anyone fit a 265/70r17 spare underneath WITH a factory trailer hitch? KDSS spacer or not?
Yeah, only class 3 though… it was tight. A little bit if a wrestling match but it fit. I could see where the tire had been rubbing on the sway bar in a few spots. Spacers gives you over an inch of extra space, so the tire easily fits now.
Thank you @URJ150L and @jdam for your info and input. I'll be buying the KDSS spacer kit to help make a proper 32" spare fit underneath my stock '14 with tow hitch. I tow a travel trailer and don't like the idea of buying a spare tire carrier. This solution will be perfect!
If you were local I’d sell you my rear KDSS spacer.
Just double checking - if you do KDSS spacers, you have to do front AND rear because of how the system works, yes? Asking because I've seen mixed answers on KDSS spacers and some skid plates regarding compatibility up front (but haven't really bothered to measure mine [RCI])
You can do just the rear if you want. I know a few people running just the rear to make sure front clears skid plate.
I've got the Treaty Oak spacers on and they don't interfear with the stock skid plate.
You hit upon an interesting point Rednexus. If you are out in the boonies, assuming dirt/gravel roads, you can drive as far and as long as you want on miss-matched tire sizes, so long as the surface you're driving on is loose and the tires have the ability to "catch up" (unwind). That's why one should never use locking hubs and L4 on pavement, the tires don't have the ability to scrub off the extra rotations.
Hope that made sense.
You can run a small spare on pavement with a Torsen diff without fear of damage.
It will only "wind up" when there is a difference in torque at the wheels, not with different rotational speeds.
Torsen engineers say OEM spares are fitted with as much as 25% difference in circumference.
After having wound up an all-wheel-drive system before with a miss-matched spare, to the tune of over $3,000.00 in 1994 dollars, with all due respect, I'll stay on the safe side and keep a same size spare. ;)
Truth be told, we LOVED that van! We had to special order it because we wanted the all-wheel drive, color and seat layout that we wanted and there was nothing in the entire state CA or even Nevada. I lowered it a wee bit, and mounted 17" wheels with 45 series low profile (all season) tires. It looked and handled awesome! Just not a lot of power, but it worked. I would have done the super charger, but the option for both super charger and all-wheel drive was not available. We needed the all-wheel drive over power on account of spending a lot of time in Lake Tahoe in the winter.
BUT, I had to replace the starter once and that was a headache! Had to remove the drivers seat, access all the bolts with 12" long 1/4 drive extensions from both under the van and inside AND I had to use my air ratchet for one bolt because there was absolutely no space for a ratchet to swing back and forth.
Then it turns out that mid year Toyota decided to change starters on the Previa so I had to go back and exchange the new starter I just purchased for another.
Now in a deep announcers voice from the 1950's...
"We will now return you to the normally scheduled OP."
I can't decide if this or a valley starter is worse now...
Just an update. Got the KDSS spacers installed on just the rear and I now have a 32" spare stuffed underneath. It's a tight fit, but it works out. You have to pay attention when cranking the tire up to make sure that it goes up straight. I had to adjust the tire a few times as it was going up to make sure that it nested in correctly.
