spacers on saginaw plate
Discussion in '40- & 55-Series Tech' started by 1969cruzer, Oct 27, 2005.
  1. 1969cruzer
    1969cruzer
    348
    Feb 19, 2004
    Lewisville, NC
    Ok so I am just about ready to get my frame painted, and i have one last thing to do.
    The spacers that hold the box mounting points even on the scab plate with all their different spacing.
    What is everyone using to make these spacers?
    Spence
  2. paranoid56
    paranoid56
    661
    7
    Apr 21, 2004
    San Diego, CA
    i used my lathe :D
    Shane
  3. bustanutley
    bustanutley
    2,285
    4
    Apr 10, 2004
    denver
    i grabbed the spacer that was on the car that the box was on, nice cast aluminum peice fits perfect, no work involved. 80s XJ
    Treeroot made his out of 1" 1/4" wall tube or somthing, the right material is out there, you just have to find it. I think he may mention it in his right up.
  4. cardinal fang
    cardinal fang
    786
    1
    Jul 13, 2003
    Folsom, CA
    1/2" Black pipe. Cheap and easy to get!
  5. peesalot
    peesalot
    2,398
    91
    Sep 20, 2004
    here
    jack handle from old cheesy sears floor jack that took a dump, sawzall , tack weld , test fit , grind to perfection , finish weld , paint......... please use grade 8 bolts of the proper length when fastening box to frame. One of the most common skimped on area's IMO.......
  6. too tall
    too tall
    1,403
    170
    Jan 9, 2004
    7/16 set collars don't work too bad .should be avail. at local tool supplier
