- Year
- 2006
- Vehicle Model
- 100 Series
- Location
- Glendale, California United States
- Mileage
- 146634
- Color
- silver
For sale is my 2006 Toyota land cruiser 100 series which I have heavily modified throughout the years I have owned it, with 146k original miles.
I have owned this vehicle since 2012 when it had 18,000 original miles. All service was done on time and I have all records, including all recommended maintenance services including timing belt, radiator, diff fluids, fuel tank vent and charcoal filter, etc. Also, a couple of items which have been replaced outside of recommended maintenance have been rack and pinion, brake booster/ABS pump and alternator.
This vehicle is modified with a:
TJM front bumper
Superwinch tiger shark 11500lbs winch.
Onboard air using a viair pump,
CB radio,
snorkel,
metal tech 4x4 sliders,
BIOR rear bumper, with custom-made Jerry can holder, and HI lift Jack.
Center Diff gearing was replace with 10% underdrive to give a final drive ratio of 4.1 x 1.10% or 4.51 final ratio. this is only for the high gearing and the low gearing remains the same.
I also have 56 inch wide clamshell rooftop tent, with custom made mounts. I custom-made crossbars using front runner mounts, as I wanted the smallest gap between the rooftop and the bottom of the tent, for aesthetic purposes.
front runner axe and shovel mount, rear LED lights 54 inch wide front LED light on custom-made brackets, as well as LED lighting inside the tent.
ARB awning with LED lighting.
2 inch lift Ironman pro-foam shocks, torsion bars and Heavy springs in rear.
The tires are 275/70/18 BFG all terrains with less than 3,000 miles on them
the new Odyssey battery installed December 2022.
All services are up to date and the vehicle does not have any mechanical or any other issues, whatsoever!
The interior is in very good shape, with some wear through the years. it has had whether tech mats since I’ve owned the vehicle so the carpeting is in almost perfect shape. The main wear is the driver side seat, left bottom bolster worn from getting in and out of the vehicle. The vehicle has audivox tv, headphones, cobra 400 watt inverter, 6 switch panel, and rear cargo are dog guard.
The vehicle has been off roaded but never abused! There is very little to No rust on the vehicle given it’s always been in Southern California!
The vehicle was involved in one accident, several years back, it was rear-ended. The plastic rear bumper, tailgate and left tailight lens were replaced. That was the extent of the damage.
Additionally, I have all of the original bumpers, running boards, roof rack, etc. from the factory and it’ll be sold with the vehicle.
Lastly, I’ve taken meticulous care of this LC. It has incredible sentimental value as both my girls grew up in this car and I had incredible adventures and it. I’m ready to let it go and hope someone else will take care of it and enjoy it as much as I did!
Please let me know if you have any questions, for quickest response you can email me at edwin.irg@gmail.com. Asking $39,500.
Thanks,
Edwin
TJM front bumper
CB radio,
snorkel,
Thanks,
Edwin
