For Sale South Surrey BC BJ60 for sale
I am lowering the price down to 2,200 dollars!!! yes need to get this sold I am moving.
Got a BJ60 with 480,000 km on it. The engine runs smooth after a full injector rebuilt 9-12 months ago. One cylinder is slightly low. I think the last time I check compression was 400 psi on all cylinders and last one was 380.00.
The truck my guess could be a parts truck. It still drives but needs a new frame as shock tube was rusted off long time ago and inner channels are in bad shape. Needs both bumpers replaced. Right quarter panel near right tail light was smashed it and never repaired. There is rebuilt injectors about a year ago cost $460.00 a New rebuilt alternator 4-5 months ago. There is a new valve cover gasket. Still has the original steelies but there is surface rust. The 4x4 still works.
It does have the brackets from a Semi Air brake tank welded on with air tank mounted. It used to have a OBA system but the bracket kept breaking so removed it. It has the remains of a Veggie system with a 10 micron Diesel filter system mounted to the right side of the air cleaner. It has a 5 plate heat exchanger but was never mounted. I still have original brown land cruiser manuals.
Window has original crack when I got the truck a decade ago
What yr is this? Also, does it have a 4 or 5 spd transmission?
It's an '84 with a 5 speed. I looked at this truck. It has some play in the t-case output flanges. Leaf springs were replaced at some point.
HeloMech, who are you? I only did one day 1 hour of off roading this truck. the truck is old and bumper and
I never met you. Who are you? I had only two people look at it really close. Anyway, I am selling it for another vehicle.
