This past weekend I installed the Sequoia 150A alternator with Photoman's bracket and small pulley with upgraded battery cables from Fourrunner. Also put on the Interstate 27F group battery yesterday. Impressions after all these is that the LC fires up after 1 crank or the most 2 cranks and my ds front windows rolls up a lil faster than before.
Now to the accessories, I re-used the stock 2 gauge wire and run from battery to the Blue Sea bus bar, then from there to AM1 box and some stock connectors. Also hooked up 2 Blue Sea fuse blocks with 4 gauge wires to the bus bar. I wish I had some 10-12 gauges wires laying around. I just used the wires came with the lights and 14 gauge that I have. I installed 7 rocker switches (3 on the left side of steering wheel and 4 on the center console) but only using 3 for offroad lights in the front and roof LED lights in the ds rear corner for back up or when I need light. All the 12V sockets are active as of now. I may hook some of the them to a switch later. Now I can charge my phone and gps at the same time so are the passengers if they need to.
