Update (5/14/24): this issue was resolved after I took the truck to Ed Martin Toyota. They found control arms not torqued to spec. Tighten everything to spec. Rubber band steering feeling is gone. Ed Martin is good. Should have taken the truck there for install of new control arms.
I’m getting very close to dialing in my 05 LX470 that I bought back in December of last year. After replacing UCAs, LCAs, shocks, properly adjusting wheel bearings, and an alignment from a good local independent shop, I’ve got just a bit of slop in my steering. For example, if I’m on a road with a very gentle crown, I’m always having to keep slight pressure to the left on my steering wheel as long as it’s under load or especially when accelerating. If coasting, I have to apply less force left with steering wheel- will basically track straight and steering wheel feels straight. . If I’m making a left to turn onto a highway, as soon as I straighten out, I have to keep steering wheel cocked about 10-15 degrees for a little while and then straighten it out gradually. Also, there’s about a 1/2” to an inch” of dead / play when steering wheel is centered on the road. I feel like I have to chase the steering more than I did before all the suspension work. Everything else is nice and tight in the front end- including tie rods. Rack is OEM Lexus for VGRS system and was replaced maybe 4 years ago / 30-40K miles ago. I’m thinking it’s slop in steering rack bushings and am considering swapping in some Whiteline or Super Pro poly bushings. Anyone have a similar experience and make a switch to poly bushings to achieve tight steering again?
