SOLVED Help with AHC stuck in low position (1 Viewer)
an Interstate group 31 Fits fine in a 200 stock battery tray
So it turns out to be an easy fix. Hooked up Techstream again last evening after work. Navigate to AHC screen and simply clear the code. And I can hear the pump working right away. Thanks to PADDO suggestion, it is all good now. After 2.5 Liter AHC fluid replacement, ride smoother. Used fluid is way overdue!
I have a 2015 LX570, just did a bleeding of AHC fluid and end up with same symptom as yours. searching on internet lead me to this thread. just ordered ELM327 OBD2 adapter, will load Torque Pro once I get the adapter. Hope just need to clear the error code caused by fluid low during bleeding. How’s your AHC system been working since the time you fixed the problem?
Works perfectly fine since clearing the code. =)
Wow! Didn’t expect such a quick reply, Thank you so much!
This is my old fluid compared to fresh new fluid, definitely needed to change.
What year is your LX and miles? Any record of previous fluid change? Just curious.
It’s a 2015 with 91k miles. there was one previous owner, probably didn’t service at Lexus dealership because there is not much Carfax records.
I am changing all the fluids except for transmission fluid now, will do the transmission at 100k miles. it will continue to have no new Carfax records as I will DIY and not go to a dealership to do the maintenance. but now I will know exactly what have been changed what what fluid was used.
Same story here. I'm second owner but first owner went to Lexus until the factory maintenance expired then did all the service at Toyota after that. Called the Toyota for service records and they never touched AHC.
Second Tek’s Suggestion. I had a dying battery and got an AHC warning right away.
I just got the same error message as in this thread. Coincidentally on the way home from the dealer, which did an AHC fluid change, among other things.
My battery is from 2018, and has significant corrosion on both terminals. I do suspect it needs to be replaced. Might have to do it sooner than later now.
The AHC stuck in low when I got the AHC error message. After making sure the AHC reservoir is almost full. I drove it for a few miles and left the car in garage. The next day it drove it again. Then after a few days sitting in garage I noticed AHC is at normal height. In that few days I did start the car a few times working on other maintenance work but didn’t pay attention to the AHC position. before driving the car in low height position I also tried to clear error using some cheap OBID2 software that didn’t recognise AHC system. From reading this thread, I knew that the AHC stuck in low because the AHC pump does not start when this code is present. Clearing the code and/or driving the vehicle in low AHC position to certain speed might have forced the pump to work. After that, the AHC works fine and I never see that AHC error code again. I suspect disconnecting battery for some time might also clear the error code but I haven’t tried that.
Mine seems to be stuck in low now, too.
This is what my reservoir looks like:
Can't for the life of me tell the exact level of the fluid.
Like you, my Actron OBD2 reader did not pick up any error codes, and was not able to clear this code.
I did just disconnect the battery and will give it 20-30 mins.
Put a headlight at top of the spare tire facing the fluid reservoir, you will see the level. I filled it almost full well above max level when the car was stuck in low. Once the car is back at normal height, the fluid level fell to in between max and min marks.
This sequence of events is long and not sure this step by step list will help explain but here it goes anyway. Numerous issues so not sure if they are causal or a result of some umbrella of system failure. No noticeable issues prior...
Objective: remove rear seats
Ignition off, in park, battery connected. Power seats have a safety latch behind the rear window so I had to stop the bracket from latching in upright position which triggered a warning light on seat switch. Removed one seat then closed rear door.
After dinner tried to open rear door but power door wouldn't activate. Lifted manually and then the power door motor started clicking repeatedly. Tried to stop motor by clicking remote, door button, and button in next to steering column. None of them stopped it so I closed the hatch manually and pressed "Start/stop button" to hopefully initiate something that would stop the rear door motor.
Engine wouldn't start but a rattling started under the hood. At this time I didn't notice a MIL. It was the canister marked nitrogen (break booster accumulator?) vibrating. I tried ignition again, failed, panicked and disconnected battery. Silly of me to think pumping break harder would start the engine but that's probably what triggered booster to start vibrating. I a read a post here about pumping break 20x and it flushed like its supposed to, no more rattling.
Upon connecting battery back up and trying to start then I noticed the MIL "Check 4 wheel AHC system". It was parked in Lo using Park Assist. Multiple times testing disconnecting battery to reset and removing AHC fuse but won't turn over. Battery is ok with power seats, lights, and rear power door all operating fully.
I tried a work around for starting in emergencies where you click Start/Stop Button to enter accessories mode, put in park, with parking break, press break pedal, and hold Start/Stop button for 15 seconds. Sounds like starter clicking away but no ignition. The engine doesn't move and no sound so I guess spark and/or fuel aren't combining. Worried I'd burn out the starter. So that's where I'm at now, I appreciate anyone's 2 cents
The word is "brake" for God's sake...
