Stone said:
FWIW...I've had my Solar Converter hooked up in my BJ74 for three years now. Not a hint of trouble so far. Cheers.
Sorry to hear the trouble mac. Do you know any techy folks who could look it over and see about fixing it?
Over 4 years in the BJ42, and over 2 years in the BJ74 now too, with no issues on the converters. Once the load balance issue when sitting or in cold weather is dealt with, and if it is hooked up correctly it seems okay. I've been running mine with a relay since the beginning of Dec, so it is in 24v-12v stepdown when off, and in load balance when running. Seems okay so far.
You're right Stone...it is not the simple typical mondo heat sink type converter.
I've had remarkably few returns and the few that have come back for checking it usually comes down to unknowingly incorrect install or use. Incorrect install: (neutral wire to frame instead of lowside battery neutral pole) (majorly mismatched batteries) (not being taken in and out of system in the correct sequence time after time and blowing fuses). All of which seems to pooch the converter over time. But, if hooked up correctly, and connected/disconnected correctly it seems okay.
I stand by the idea if you want plug and play, or are having someone else hook up the converter....then hook it up in simple 24v-12v convert mode only. Even then you have to be aware to take the converter out of the system before you disconnect the batteries. If others work on your vehicle this is not done unless the owner tells the tech.
If you are doing your own install, understand the converter and pitfalls of load balance mode, then play away...
It's pretty much covered in this thread:
https://forum.ih8mud.com/showthread.php?t=33070
hth's
gb
