Soft open lower tailgate for LC
Colorado
Has anyone installed this part from the LX on the LC? Anyone know the part# and cost?
Not sure what all would be required, except I'm pretty sure wouldn't be cheap. The damper part alone is north of $300 (retail). Part name (use for searching) and part number is: Lexus LX570 Base Damper | Lexus OEM Part Number 67028-60010
I can say that it is a pretty nice feature on the LX tail gate. It is just a large spring type of operation in the cylinder. It assist going up and down because of this.
Let us know how that works out, I’d definitely consider putting it on mine as well.
I am not sure, this is most detailed info I can find about it.
LEXUS BACK DOOR LOCK & HINGE
Does anyone have a playbook on how to R&R this piece?
Thanks for the diagram. I ordered the left hinge, at $54 its worth a shot. Looks like I would have to do some drilling to mount the damper as it has a bolt to hold in place. No hole there on my 08. Or could I possibly use some type of adhesive? I'll have the parts probably late next week at the earliest, but once I get into it I will post how it goes.
Thanks, yep mine also looks like a fresh bolt will need to be drilled to hold the right side anchor point(when looking from the rear), can't wait to hear how it goes. Can you share the .jp link from ebay?
Left Hinge part # is 6612060020. I ordered the bolt that attaches the damper to the body (part # 91673A0622, $0.62), it does not appear that it comes with the damper. I might also replace the "Check Cables" as Toyota calls them (part # 65706-60030) There getting kind of rusty at 180k miles in the northeast.
I think you might need this part to fit into the damper assembly, the hinge itself may need to be replaced in order for the rod to stick out from the hinge and into the damper assembly and use its spring
Lexus Part No.: 66120-60021 (replaced the part you mentioned, same part)
That part # is for 2013-16. The part # I referenced was specific to 08 LX. I checked the diagram for the 08 tailgate and it does show the bolt extended from the hinge to meet the damper. They are probably the same? Just changed the part #? I'll wait and see what comes and if it works. Thanks for the info.
Yep, looks like a # change only, same design and function.
HAH! I've been planning on doing the same retrofit for a while now. You definitely have to drill in some new bolt holes. Let us know how it goes.
Hah, I was going to tag you in this but I figured you'd see it.
