bmorefj40
Just like the title says, I'm getting ready to build or buy a CNC plasma table in the next 6 months. I've been reading on the topic over at weldingweb and cnczone for a few months now and I think I can at least ask some good questions. I've always respected and got some good advice on this forum, so I decided to start a thread here for my benefit and anyone else in the same boat. I'm going to put a laundry list of items for discussion here and hopefully narrow down my choices.
First, I thought I was sold on the idea building my own table, but reading through the hundreds of posts about issues with a diy "kit" table and the related software to hardware integration, I now know that this can eat up countless hours/weeks. I'm confident I can build it, build it well (level and planer), and connect it all together, but the software and g-code thing can be a little intimidating. So, plasmacam enters the equation with their designedge software that does get a lot of praise. Arclight and LDR are also other possible solutions. This is a side business/hobby for me and I don't want to spend 2-3 months just learning how to cut out a circle. I would be using this for custom metal furniture that I build and its been getting enough looks that bringing the plasma in house makes sense. (Can't seem to find anyone in the Bmore area that will cut less than a 100 pieces for me). Most of the time, I need to just make 2-8 pieces of something and it's getting more complex than my hand can do (well). Material thickness is mostly 18 gauge to 3/8's, but could be thicker (1/2") on a very small one-off basis.
Brands
DIY Kit:
Precision plasma
Bulltear (also turnkey)
Turnkey:
Plasmacam
Burntables
LDR
Arclight
Questions about the vendors:
*Length of company history and customer satisfaction- I hear great things about Precision Plasma and CandC, as well as plasmacam, but I hear horror stories as well. Anyone here have relevant experience with some vendors?
*Warranty- What should be expected?
*Replacement components source (proprietary or off the shelf)
*Programs included (cad/cam- sheetcam, mach 3, design edge, etc)
*Plasma compatibility- I have TD Cutmaster 52. I know hypertherm might be a better solution down the road, but this will have to work in the interim.
*Type of x / y rail- V-rail or flat CRS. Rack and Pinion is a must. I don't want chain or balls crews in this application. Dual drive x axis is a must.
*Type of z mech: how many starts do you need? I've seen 2-start all the way up to 5-start. Also, is 1" acme necessary. Some only go up to 3/4". I need capacity for 4 inch tube to be laid on the bed and cut. Wood routing and plate marking are options I would want down the line if things go well.
*Pc requirements- this seems pretty universal and simple. Something that has a parallel port or space for a pci card that has one. Anything else?
*Gantry kits or turnkey- any issues with the kits that I should be aware of?
*Shipping cost and packaging- I'm on the east coast and haven't seen any that I can easily drive to and pick up, so this may become a factor. Wish some of these vendors were closer so I could inspect them in person. Might be able to do that before purchase, but I would have to be pretty close to the final decision.
*Bearing type- does it matter?
*Auto digital torch height control- this is a must, but I've seen touch-n-go, ohmic sensing, and I think one other type. Any advantages of one over the other?
*Wipers on rails- Is this necessary or does mounting location of them make it moot?
*Water table /water bladder- I don't have the ability to vent a table properly, so it would have to be a water table. since this isn't production use, I think a water bladder would be necessary to drain the table and adjust water height easily. Correct me if I'm wrong here.
*Rail replacement options- I heard some of the v-rails can get pricey. What is the life expectancy of these items?
*Sheet loading- I'm a one man operation, so ease of loading is a big consideration. I may need flat or below bed rails so i can easily place and remove sheets.
Servo vs stepper- Seen this debate everywhere. I think servo gets the nod in the industrial world, but steppers should be fine here. Is there anything I'm missing other than the bi-directional closed-loop set up of servos? I plan on mostly cutting from 18 gauge to 3/8's.
*Gear reduction- is this necessary or should I avoid it?
*Max ipm cutting- based on my depth of cuts, what ipm range should I be shooting for?
*Resolution- seems like .01 should be realistic, but correct me if I'm overly optimistic
Sample Est Cost for a Gantry Kit
Precision plasma HD 5x10 Gantry kit 6000
CandC Electronics- bladerunnwr with auto dig torch height 1500
Steel for table and crs for rails 1000
Software 300
Air dryer and pluming 500
TD 52 Mech torch 500
Computer and monitor 500
Misc fasteners and switches 500
Water table bending and slats 500
Air/water bladder plumbing 500
Total cost 11800
If you guys have costs for your set ups, please post them up. I know this was an extremely long winded post, but just looking for advice from guys that have done this or other people in the research phase that may other things for me to ponder. I'll try to do the same estimated cost breakdown for the other options as well, but I think that's enough typing for today.
Appreciate all the help!
Brands
DIY Kit:
Precision plasma
Turnkey:
Plasmacam
Burntables
LDR
Arclight
Software 300
Total cost 11800
