I am trying to gain more experience on retrofitting lol so when it comes time to do my hundy, I will be better!
Small writeup on the retrofit I did today! 2006 Nissan Xterra
Some info on the projector retrofit
Projector: Morimoto mini H1 bi-xenon projector
HID: 6000k 35w H1 kit
Projector shrouds: Newly released MC-R shroud from TRS. 18SMD LED strip to light up the holes in the shroud, used as a DRL
So first begin by taking apart the bumper. Open the fenderliner and remove the two bolts holding the bumper to the frame. Remove the headlights abd grille
Now open up the headlights and fit your projector and shroud together. Dremel as needed
Using the LED strips, mount them behind the MCR shroud's mounting ring. TRS puts out great retrofit products!
Since I sell LED dome lights and other map panels, I decided to create an adapter out of some spare t10 dome light adapters to use on the LED strips. This way, the LED strip mounted behind the shroud can act in the same manner as the original park light/DRL
Adapter showing
Adapter hidden, looks factory
Seal the headlights up using RTV silicon after reheating the oem glue and reusing the oem headlight glue. THIS IS STRONG ADHESIVE!
Mount and hide the HID ballasts while waiting for the headlights to dry. Cut the H4 to 9006 Harness. Since this is a bixenon projector, you can cut the high beam portion of the HID bulb(which is halogen). DO NOT CUT THE LOW BEAM WIRES
Mount them up and test all the components. Make sure to check check and recheck! Now appreciate all the hardwork you put in!
only the DRL's lit up!
These are pictures of the new projector setup with the 6000k HID bulbs lit up
