So I contacted TRS about a REAL group buy for projectors, lets get it going! (3 Viewers)
I say go 4.5k range whether 35 or 55 watt.
I dont know, I was kind of thinking about the 15Ks...
I agree as most OEM lights are 4300 or 4500. I don't want my truck to stand out.
Goodluck hiding the fact that you have projectors in a 100 series:)
The 15k's come with free purple hanging dice haha
Problem is that I don't know what the full kit means!!! I'll get it figured out :).
I can help out;)
Full kit contains:
"The Morimoto Mini bi-xenon complete kit includes the ultra-compact Mini bi-xenon projectors, the proper HID bulbs, and a set of 35w digital Morimoto ballasts to power them. It doesn't get any more "plug n play" than this." (Theretrofitsource.com)
Bi-xenon Morimoto Mini Stage III Kit (H1) - Complete Retrofit Kits from The Retrofit Source Inc
Full kit starts at $270
So for those of us with the 9006 55w ddm kit:
can we get a 55W H1 bulb from TRS?
Or will the 35W bulb work with the setup I have now?
Or Should I just order the 55W H1 bulbs from ddm for $15?
Alll 3 are options! But, you can keep the warranty from DDM ballast only if you keep using DDM bulbs!
I want my lights to be white, not yellow as the OEMs are.
As far as wattage goes, Is light output related to the balast or the bulb? Can you use a 35W Bulb with a 50W Ballast? I'm asking because the kit only offers the 35W bulbs but offers a 50W Ballast.
Ok awesome, then I will be ordering the 55W H1 bulbs from DDM.
I'm locked in for just the projectors with the basic gattling gun shroud.
3. petrotk40: Morimoto mini H1 projectors with 9006 adapters, [STRIKE]H1 bulbs[/STRIKE] and chrome mini gatling gun shrouds
man, reading hoser's thread... I'm a bit nervous. It'll be totally worth it when finished tho. I just hope I don't have to buy a new headlight...
One question about the bi-xenon:
For the 100, the DRL's are on the high beam circuit so I couldn't run bi-xenons. The high beam still works well though as the low beams have a sharp cut-off and the hi beams have no cut-off. Halogens are supposedly better for "flashing" because they turn on instaneously. HID's have a short delay when the lights "heat up." But I would probably have done bixenons if it wasn't for the DRL's.
how do we get the high beams to get the bi-xenon to work?
I will ask Matt at TRS! The tacoma and 4runner is setup like the hundy and many people have done bi-xenon so I will check!
Also, maybe this will get people interested! I changed my mind and want to get these shrouds...worth the extra $$$$ and larger CCFL rings
Gatling Gun 2.0 - Projector Shrouds from The Retrofit Source Inc
man looking at pics, I'm so pumped:bounce:. I just hope I have enough :banana: to not break anything in the process.
Hmm, well... let me rephrase what I said 5 years ago. The LX has a LO beam bulb and a HI beam bulb. The DRL is the HI beam at "half volume." Using a Bi-xenon projector, where the HI beam is a matter of mechanical shield that flips up to change the beam pattern, it is possible to have HI/LO bi-xenons in addition to the existing half volume DRL's. The HI beam trigger wire will have to be sorted out... from the HI-beam circuit.
Does the LC100 have a completely different bulb for DRL's than the HI-Beam? If so, it will make things slightly easier. In any case, YES, you can have great working HI-beams with bi-xenons as the HID's remain on... there is no warm up time other than when initially turned on. Is that any clearer?
But I do think it would be wise to read up on some retrofits. It is not hard but it can take some time. The end result will pay off though.
the LC's are the same as the LX's where the DRL is the HiBeam not at full power.
Okay, found a pic. So, the HI-beam is on the bottom and the LO is on the top, right? If you can install the Bi-xenon projector into the housing while retaining the existing HI-beam bulb, then you can have HI/LO and the stock DRL's all at the same time.
But like LJ mentioned, you can also get rid of both stock HI/LO and go a different route for the DRL's... whether it be a smaller bulb, angel eyes or whatever floats your boat.
Thanks for chiming in hoser! I will see if there is some kind of way to get hi and lo to work! I'll do some research to see what other people have done! I have done some research on the retrofit procedures on hidplanet.com:D
The answer regarding the hi beam and DRL being on the same circuit has been answered!
TRS also said that when the DRL is on that the hi beam shield will be up in the bixenon projector, but since no light is being emitted from it, it will not matter that the shield is up. So having the DRL and hi beam on the same circuit is not a problem because once the low beam is switched on, the DRL goes off and no current runs through the hi-DRL circuit so the hi beam shield in the projector will go down!
Called about these questions...
Regarding the H1 bulb: I mentioned to TRS that people here have bought a DDM kit so a lot of people want to buy the H1 bulb from DDM in order to avoid the ballast warranty from being scrapped. He said the H1 from other brands has been used before and it possible...people have done the morimoto projectors with different h1 bulbs and doing it with or without trimming to the bulb base
Regarding the light vents in Gatling gun projectors: The gatling gun projectors have light vents but light is emitted forward rather than all around in other directions! So the light vents do not cause any funky light spread! In addition, if you want the Bimmer look, you can do the Ocular, E46 or E55 projector because on those shrouds, the CCFL can be mounted in the front!
Hope this helps:D
I just want to add from what I've read in the past and my own experience with at least 5 different generic aftermarket ballasts, the Morimoto ballasts are far superior to just about any of the cheaper ballasts found in most HID kits.
Snapped a quick shot of my younger brother's Q45 gattling gun projectors that he plans to retrofit into his GS300. Wicked setup for rounded headlight housings, like the FJ60s for instance. These things are massive. So to put things in perspective, our aim in this thread is cake compared to what my lil brother is going to do.
