TRS also said that when the DRL is on that the hi beam shield will be up in the bixenon projector, but since no light is being emitted from it, it will not matter that the shield is up. So having the DRL and hi beam on the same circuit is not a problem because once the low beam is switched on, the DRL goes off and no current runs through the hi-DRL circuit so the hi beam shield in the projector will go down!
Perfect, that's the exact answer I was looking for. I guess it doesn't matter the current running thru the circuit that controls the hi/lo beam shield?
I need to check a few things when I get a chance.
1. do the DRL's turn off when the lo beams come on?
2. do the low beams turn off when the high beams are on?
if #2 is true, then how are we going to keep the HID's on when we turn on our brights?
