Finally getting around to posting some pics of my recent install of a Smittybilt XRC12 winch with ARB bumper. The mechanical side of the install was rather straightforward other than a couple of little tricks. Wiring in a second battery, isolator and Blue Sea switch to feed a hungry 12,000 pound winch took a little longer.
The first pics are of the various parts. I used the 80 series ARb winch bumper. Other options are available, but I like the classic look of the ARB and it suits our expedition type build up well.
To help mount the winch properly in the bumper, I ordered an ARB 3500050 Spacer Kit. It's listed as being for a Warn winch, but in reality any planetary-style winch will likely require similar consideration and something similar to the kit parts.
The ARB 3500050 Spacer Kit consists of 4 think metal bars (1/2"?) with holes punched in each end. Placing them between the bumper and the winch pushes the winch back when mounting it in the angled nose of the ARB bumper. Wider/longer winches may be too wide/long to mount properly with the feet forward. This can cause broken castings if you aren't paying attention and crank the mounting bolts down without providing for this problem. If you have equipment to cut and punch similar pieces, you can do this and don't need the kit. The kit also includes a handy license plate mounting bracket (if needed in your jurisdiction) and a few other bolts, etc.
In my case, the 12,000 pound winch is supposedly the same dimensions as the 10,000 Smittybilt pound winch in the literature provided with the winch. I saw another install where it looked like the 10k winch may actually be narrower/shorter than the 12k. YMMV, but in any case, you want to provide enough spacers under the winch feet to be sure that you don't break anything when tightening down the mounting bolts.
The pics show the bumper on the ground, protected by cardboard face down. This is the easiest way to get things lined up and bolted together squarely when attaching the winch to the bumper.
