I also think the fuel pump is leaking gas into the crankcase if it is not then your rig is running really rich. ...but yep its time to do a compression check.
Although the gas smell in the Rad pretty much nails it, there is a kit you can buy from Napa to confirm the problem:
Head Gasket or Combustion Leak Test Procedure (Gasoline Engines Only)
Then you coul...... "Leak Down" .
How to do Cylinder Leak Down Testing- Car Craft Magazine
Mark
Duh, forgot some of these weren't injected and had a fuel pump attached to the block. Had that problem on an old cherokee a while back.
good thing
Like everyone else says, though, it's time for at least a compression check. While it's possible a few things could fail at the same time, it's a lot more likely that it's just one thing causing all the symptoms.
Oil Cooler x2...Bypass it temporarily
the oil on the stick is brown? radiator smells like gas. does it shoot water out the filler neck when the cap is off and running?
pull the head-
oh and good luck
matt
X2^ Chocolate Milk looking anti-freeze means oil got in there somehow. Do a compression check first and see where it leads you.
[/QUOTE]I changed(garage) when I got certification done. Along with ALL fluids besidesrad.
I ll double verfy if THEY did the job,paid cash to save 15% rear,transfer case,grease every greaseable'S.
Then I get more familliar with my FJ60
No Steam out of muffler
FJ60 2F I ll attempt pulling(heads+gaskets/boats) crammin(stuff),stompin(anyt'in),pushin(more)climbin(higher) now to get it started! no more CLIKKs please
Mark
I think Tntoyota/Hilux has a Canadian cousin.
