SmartWasher® OzzyJuice® SW-4 HD Degreasing Solution (1 Viewer)
Malleus
Far west of Siegen
Charlotte, NC & Alexandria, VA
This is primarily to answer an aside from the front suspension topic it was pulled from, so as not to contaminate the OP's post topic.
So, @2001LC and I were chewing the fat about degreasers, (kudos to Paul, who happens to be the only other person I know of who believes cleaning is a maintenance step) specifically, SmartWasher® OzzyJuice® SW-4 HD Degreasing Solution. He likes it, which means it's pretty good, in my book. It is spendy, though.
The question was asked if I knew the formula for the CRC orange (priced as gold by weight) degreaser. I didn't but promised I'd ask a chemist at work. So here's the answer.
We searched (which is what we both do for a living) and there doesn't seem to be a patent or patent application for this stuff. My inital thought was it (just like every degreaser I know of) is a lye– (sodium hydroxide) based solution. The ad copy says something like:
"eco–friendly, biodegradable, non–hazardous, pH–neutral, water–based" degreaser.
What this really means is that the solution is primarily water, as opposed to petroleum, and whatever is in it that actually does the degreasing, is in such small amounts that it doesn't meet the threshold limits for "hazardous". What this DOES NOT mean is that it's safe to drink (or let your favorite pet lap it up).
I'm not a chemist, but my chemist co–worker agreed with my guess that it's lye, in a very small amount, that does the work (based on the fact that it's the most common industrial degreasing agent, and thus the cheapest), along with a fair amount of soap (the surfactant in the solution), and some dye, and maybe fragrance. This is based on the information in the MSDS:
In order to have a pH of 8, (since deionized water has a pH of 7), the miniscule amount of active degreaser has to be pretty alkaline, which lye is. A bit in a gallon of pure water will raise the pH significantly. Not enough to kill you or take the hair off a dog (as my grandmother was wont to say), but still enough to decombine grease molecules, which is all that's required to make them "unsticky" (not a chemical term...).
So there you have it. Paul says it's good stuff, I can't make it, it's more expensive than ZEP purple degreaser (which I have too much of), and that's about all I know.
He also uses SmartWasher® FL-4 OzzyMat Multi-Layer Fluid Active Mat, which he likes too.
Actually, this started as a comment I made about his insane volume of Evaporust. FULL DISCLOSURE: I'm guilty of the same sin, in the past. The comment I made was that you can save a lot of money if you make your own "DIY Evaporust":
in (1) liter (or quart, your choice) of distilled water (this is not negotiable), add
(100)–grams of citric acid, and
(40)–grams of washing soda (sodium carbonate). You can add a squirt of liquid dishsoap, if you choose; it won't affect the derusting abilty, but it does make the solution sticky(–ier).
IME, this solution works better and lasts far longer than the commercial solution. Try it and LMK what you think.
If you absoutely have to use baking soda (sodium bicarbonate), use 65–grams instead of the 40–grams of washing soda. You need the extra to make up for the hydrogen in baking soda, that isn't present in the washing soda.
I mix this in quantities of 1/2 a gallon, in a two gallon bucket (actually a plastic wastebasket), because it is pretty exciting while it releases the gas (which is totally harmless). Adding dishsoap makes even more bubbles, and they stick to everything. Make sure you have a lot of extra room. Any spillage will require you to clean everything in sight, not just what the solution managed to clean for you (you'll have a very clean spot where it overflowed).
For reference, you can use these:
Citric acid: (about $5; one jar will make about 1/2–gal)
Washing soda: (about $5; one box will make as much solution as you can use in a lifetime, and make your clothes cleaner, too!)
So, for $10, you can make 1/2 gallon of evaporust, or $20 for a full gallon. Harbor freight is selling a gallon for about $30.
If you buy citric acid in bulk, for about $20/5 lbs, or 2200 grams, which is enough to make 5.5 gallons, you come up with $30 for 5 gallons, including the cost of water.
The best price I could find for a 5 gallon bucket is Summit Racing, at $90. And that doesn't include tax and shipping.
Nice write up @Malleus !:cool:
Any clue, on how to make the microbes (OZZY's)?
Can microbes live in lye?
What I like, about the CRC SmartWasher systems, is: Bioremediation (eats grease).
I no longer need to worry about washing petroleum (grease & oils) into the environment, when I rinse parts with water. Nor do I need to, dispose of cleaning solutions (solvents) full of petroleum waste.
The filler matts, must be replaced every 30 days. Which are microbial-infused OzzyMat filter. Bioremediation is the use of microbes to break down and “eat” oil, grease, and carbon-based contaminants. Botechnology, is used to assist in the clean-up of wastewater treatment ponds and lagoons in petroleum refineries and industrial manufacturing facilities all around the world.
CRC offers a number of cleaning solution, for the SmartWasher (SW). SW-4, is one of the cheapest and most readily available. Sometimes I use the stronger X-1. X-1 is so strong. I must use a fan to blow away fumes, or I get nagging little cough. I understand they are reformulating the X-1, so it can be sold in states now prohibited X-1. X-1 cost ($200) is higher, than the SW-4 ($120).
Few things about the SW cleaner and cleaning solution:
  1. Not meant to be used to, soak parts in.
  2. Does not rinse off oils and grease. Greases & oils must be agitated with brush or rubbing solution washers over it (washes away).
  3. Acid approved gloves, should be used. It causes fingernails to crack when I get on them. Nitrile gloves, fall apart 1 or 2 hours later.
  4. Evaporates, so must add 5 gallon jugs, when gets low (light comes on heater goes off). So the more use, the more often must be added.
  5. What I don't like, is cost to maintain. Which is cost of filters and cleaning solution. The machines (tanks) themself are a one time costly investment.
The "OzzyJuice® SW-4 HD Degreasing Solution" I only used in the CRC SmartWasher. Mine is the SmartWasher Model 23 on wheels. A 15 gallon tank with pump, nozzle & brush and fluid heater. CRC has number of larger models that hold even more solution. All except bench top model (3 gal), use same fluid and filters w/OSSY's
Paul, neither I, nor my chemist coworker, is a biologist, but we'll ask around the office and see if we can get any more useful information. As far as I know, yes microbes can live in an alkaline solution. There are types which can live in acid, alkali, temperatures above and below the boiling/freezing point of fresh water, etc.
Thanks very much for this insight. I agree that, apart from the cost, this is a very attractive solution.
Fred
I'm going to try the degreaser. I've got a large plastic parts washer w/ 50gal or so tank so if the diy degreaser works it will be perfect for that.
I switched from Evaporust to Rust 911 a few years ago because of cost and the 911 works better/lasts longer at least for me. 911 is $80/gal but is a concentrate and dilutes 15:1 or $5/gal. But I tried a similar citric acid/wash soda mix a couple months ago out of curiosity and wasn't impressed. Seemed like it worked but not as well as 911. Even bought 10lb of citric acid to keep cost/gal down but there still wouldn't have been enough of a cost saving to make it worth the trouble.
This is starting to look like endorsement for CRC...LOL
Using CRC OZZYjuice, SW-4, X-1, etc. As a stand alone cleaner. May not be economical or that great a cleaning solution.
The CRC OZZYmat FL-4, embedded with the petroleum eating microbes. Along with the CRC SW tank, with it's heater. Results in system, that eats the petroleum, out of the OZZY juice. The heat aids the cleaner, just as hot water aids washing dishes, clothes, etc. The heat, also promotes the microbial action. Microbes, indirectly aid in cleaning. By removing the petroleum from the OZZYjuice, keeping juice fresh. Without the microbes, it's just a water based cleaner, that would need disposing of, like any water base clear or petroleum based solvent.
I'll add one thing that attracted with the SW-23. Is that it is on wheels. I found my SW-23, used on FB, for $100. I've most everything on my shop floor on wheels. Which allows me to, reconfigure my small shops as needs, on the fly.
I've a water based cleaner, that was given to me. It's a concentrate, that mixed 1:50 parts water. It's super strong at 1:2, will remove paint. I used, with Harbor freight parts washer. I'd rinse parts with water, in the street gutter. You could follow the back trial upstream/hill, to my door. I'd also have disposal issue as tank became contaminated. CRC SW-23 solved those issues for me.
Before EPA restricted sales of solvent and carb cleaners, IIRC pre 1980's. Just soaking parts removed most anything. Today, I find kerosene, low odor white kerosene like a can of coleman lantern fuel. A good solvent cleaner.
CRC, also has a bench top 3 gallon system. This uses different microbes and cleaner, that doesn't have or need heat. It "may" be better as a stand alone cleaner, but IDK that!
  • Back
