Not sure if serious, or trolling. I don't really care what anyone calls it or the semantics around it having Hi and Lo range making it full time 4WD vs AWD. I just want to know if dissimilar tire circumference will cause damage.I’m curious why everyone calls 100s AWD
Because they have a center differential. Same with 80s and 200s.I’m curious why everyone calls 100s AWD
This.You might be able to get away with a minimal difference that occurs between manufacturers, say 33 vs 33.4, but you can't run totally different sizes, like 31 and 33.
Teslas are awd and lack a center differential. Doesn’t awd imply power to 4 wheels but no transfer case? With transfer case=4wd? Or is it just used interchangeably for anything with power to 4 wheels?Because they have a center differential. Same with 80s and 200s.
You’re actually going straight most of the time. Most awd/4wd systems are part time or open, and become active via viscous coupler or other during slip. Mismatched tires beyond a certain spec can trigger the system to run all the time, including on the highway, overheating components causing premature failure. It can also affect abs, traction and stability systems, and tpmsneed a little education due to my opinion: front/back...side/side tires always turn at different speeds due to cornering (at least on paveement w. center diff open). the diffs are designed to handle that. otherwise manufacturers would advise against turning.
tires of different diameter also turn at different speeds.
Please explain how the two affect the diffs differently.
Yeah, I'm not talking about different tire sizes, I'm talking about replacing 2 tires instead of 4. Same tire size, but different circumference due to wear. Like I said some vehicles have pretty strict tolerances on that. Sounds like that's not an issue for the 100Only thing to really think about is yeah you might throw an ABS light when the system senses a wheel is turning at a different compared to others.
So once the ABS light on
1-No ATRAC
2-No ABS
3-Don’t even think about locking that center diff.
YMMV,
Good luck…
I do wanna ask what you’re doing?
Well, Teslas have motors at the front and rear so they are a little unique vs something with an engine. AFAIK everything with one engine driving all 4 wheels will need to have some sort of transfer case. But having a differential (AWD) will allow different power distribution front to rear, a straight geared t case (4wd) drives both axles at the same speed, not great for road use. When you engage the CDL, then you are in true 4wd.Teslas are awd and lack a center differential. Doesn’t awd imply power to 4 wheels but no transfer case? With transfer case=4wd? Or is it just used interchangeably for anything with power to 4 wheels?
A standard Subaru won’t have a transfer case, just a center diff. No hi/low range, like a 4wd would have.Well, Teslas have motors at the front and rear so they are a little unique vs something with an engine. AFAIK everything with one engine driving all 4 wheels will need to have some sort of transfer case. But having a differential (AWD) will allow different power distribution front to rear, a straight geared t case (4wd) drives both axles at the same speed, not great for road use. When you engage the CDL, then you are in true 4wd.
AWD is when all 4 wheels are powered all the time. On a vehicle with a single ICE, that normally means that you have 3 diffs, one in each axle and one in the transfer box between front and rear. If you have several engines, or motors, you might not need any diffs in order to take up the difference in speed (travelled distance) between the four wheels. In a dual motor electric car with AWD, you have one diff for the front and one for the rear. There have been made cars with four motors as well, one for (or inside) each wheel, and then you have AWD with no diffs.Teslas are awd and lack a center differential. Doesn’t awd imply power to 4 wheels but no transfer case? With transfer case=4wd? Or is it just used interchangeably for anything with power to 4 wheels?
Many awd systems do not power all the wheels all the time. They use clutch packs and/or electronics to engage the other axle, and 97% of the time are 2wd for economy.AWD is when all 4 wheels are powered all the time. On a vehicle with a single ICE, that normally means that you have 3 diffs, one in each axle and one in the transfer box between front and rear. If you have several engines, or motors, you might not need any diffs in order to take up the difference in speed (travelled distance) between the four wheels. In a dual motor electric car with AWD, you have one diff for the front and one for the rear. There have been made cars with four motors as well, one for (or inside) each wheel, and then you have AWD with no diffs.
My old Tercel 4wd, and my old 80-series 4wd (Africa Edition), also had a transfer box, but without a diff. The function is only to connect the front propeller shaft to the rear, so that the front and rear axles are forced to move at the same speed. That is a really good solution on soft surfaces: Driving winter roads with several inches of fresh snow is very stable (just like CDL-on for the 100), and that is something you don't get on an AWD without a CDL. No Atrac or ESC is as fast and immediate as a diff lock.
makes sense (oil temp)You’re actually going straight most of the time. Most awd/4wd systems are part time or open, and become active via viscous coupler or other during slip. Mismatched tires beyond a certain spec can trigger the system to run all the time, including on the highway, overheating components causing premature failure. It can also affect abs, traction and stability systems, and tpms
On the 80/100/200 there is power to all 4 wheels, all the time, and most can transfer power by vc or electronics where needed. Part time systems only have power to 2. Many awd systems lock the center diff and many 4wds are completely open so having a differential lock can’t be a defining feature. I guess it’s really just semantics.I think it's all arguing semantics and playing with words for marketing purposes. IMO, it's an AWD until the center diff is locked. That doesn't make it any less if a 4wd than a traditional part time 4wd that is 2wd until the transfer case is locked.
