Here is a good link in regards to 315's
35" tyres on landcrusier
If you are not going to do really hard wheeling you should be fine. A body lift would help a little to help prevent fender/body rub on both front/rear respectively.
Also you can lower your front bump stops on the front and rear to help rubbage. As well as what was mentioned above, adjust turn stops.
Lowering front bump stops can be achieved by adding a couple fender washers under the bump stop (Pretty easy, unscrew bump stop and add washers)
Lowering rear bump stops would require at least .5-1 inch box metal cut/drill to fit underneath.
This also depends on what type/brand/model. Each will vary. Some are larger than others from what I read. This is just a starting point of fitting 315's.
As for the lift, if you are not adding any weight on the hundy as for bumpers/armor/ect....
-You can just get away with cranking up the torsion bars (wouldn't really upgrade the torsion bars unless you have some weight on the front as for bumpers),
-adding a slee/BIOR/DIY diff drop (
Finally finished the Diff Drop today or
Custom Front Differential Drop - John Shotts (shottscruisers),
-and adding a 1 or 2 inch spacer in the rear to match the front lift or a 865 OME rear spring (2-2.5 inches unloaded).
I wouldn't lift the front past a 21.5 inch hub to fender measurement (regardless of tire, that is where a body lift would make it look higher/lifted if that is what you are trying to acheive).
YOU ARE LIMITED WITH THE IFS ON HOW MUCH YOU CAN LIFT THESE in regards to front suspension.
You need at least a 2.5 inch droop to be able to run safely and may develop caster issues (that's where you can run the aftermarket UCA' like
Slee - SPC Upper Arms - Details to control the caster setting)
Total droop is ~23.75 inches.
*Front Lift measurement Limit hub to fender* 20.5-21 inches safely without caster UCA's and can go as far as 21.25-22.25 inches with aftermarket UCA's (yes $500 for an extra inch. LOL)
Hope this helps a little.............
