Alright, this one is for the real gearheads and certified wrenchers.
Ill very soon have to go back into my brakes to fix that knicked piston boot i saw, so everything is coming apart again (including some other fixes to my front end, and a rear mod).
Anyway, picked up parts today and doing a whole rebuild front and rear, piston seals, and slide tubes in the rear while im there.
Also going to buy a slide pin grease that guarantees no swelling, since my CRC kit has gotten mixed feedback on usage instructions for rubber...
Now on to the main point, there are several fasteners which are marked as single use in the diagrams and FSM that I've ignored to replace on the first go around, because i wasnt sure if i would like the aftermarket kit i put on and literally no one seems to do it on brake jobs. I did also ignore the top shock mount bolt since im planning a replacement down the road anyway...
Now, none of these bolts are torque to yield, and none are pricey. The brakes are around 60 lb-ft and the shock mount is like 34... So i never really worried much.
I did just pick up a set though brand new hardware for front and rear caliper/bracket along with my new serp belt (bando for the curious) and they are all grade 11 stamped and have a green what looks to be anti seize or adhesive already on them...
What is this green stuff, how concerned are you guys with these "single use" cautions, and what kind of insight can you share?
From all my experience, i have never seen bolts do anything but seize up. It would really blow my mind for things to back out on their own.
Thanks in advance! Trying to do thiis as "perfectly" as I can on this go around. And its a safety area to boot.
