Should I remove the spacer from my 6112s
Illinois and Alaska
I currently have 6112s on the lowest setting with a 1" poly top out spacer. I'm thinking of upping the preload on the 6112 springs and dumping the spacer.
Any thoughts on if I'll notice a change in ride quality?
I would avoid spacers above the TopHat at all cost. Unless you spend the energy to insure the bumpstop is still engaging before the shock bottoms out.
If you remove the spacers and lift using the snap ring, the ride will be more firm (i.e., less brake dive and body roll).
