Shmukster looking for help with his 40 (3 Viewers)
NE PA coal region
Guys- my 40 has been running rough ever since the not Coal Mine event and I'm really struggling to see what the problem is. I posted this blurb in the 40 section- take a look and feel free to comment as I am about out of ideas. Thanks in advance for looking!!!!
I'm frustrated with the way the engine in my 40 is running. It started a few months back, it wasn't idling quite right, left a friend drive it at a recent offroad event and it progressively got worse. Frankly I was embarrassed at the way it ran for him. I drove it home without a lot of trouble, but it is at the point now where I wouldn't drive it on the road. Here's the skinny............
It's my 76 FJ40, the engine is from an 87 FJ60 and is a Jim C performance rebuild done about sixteen years ago. Ran great for all these years. Stock carburetor rebuilt by Jim and stock intake, has Manafre headers, and the stock fat body electronic distributor. Diaphragms have been bad in the distributor for years so no vac advance. Compression numbers are all high 120-high 130 and that's tested dry so that looks good to me. The spark plugs looked decent when I started to look at this issue but I replaced them anyway with brand new Toyota plugs. Distributor cap and rotor have been changed all these parts are OEM Toyota.. Has brand new Denso ignition wires. When idling or driving it sounds like there is a misfire- you can hear it in the exhaust and feel it.
When I remove the spark plug wires one at a time with the engine idling, idle drops significantly when numbers 1 and 6 are pulled, hardly at all with numbers 2, 3, and 4, and slightly with #5. When I happened to look down into the engine bay when it was running rough I noticed that through the large diameter vent hole in the cap I could see sparks jumping around. Thought that was it, pulled the distributor and replaced with another stock distributor. Still the same problem and I must say while replacing the distributor I had removed the valve cover and all looks well with the rocker assembly I didn't see anything amiss in there. I've looked at all the vacuum sources and don't seem to have anything open there, and I did put a socket on the manifold bolts and nuts but they're all tight. I've even changed the carburetor to another, and the problem persists. Frankly I don't believe it's a fuel issue but who knows?
Would be interested in hearing some opinions and hopefully have someone steer me in the right direction. I've owned this truck for fifteen years, have owned the engine even longer (it was in my orange and white 55 when I flopped it), and have never before had a performance issue.
Does it run any better when its cold or hot?
Have you checked to make sure there is no head gasket issue? I've seen this intermittent on the 2F with head cracks.
It could still be a vacuum leak somewhere. I have had leaks between the carb and carb spacer and also at the gasket surface at the carb mount. I have also seen cracks form in the intake manifold...especially under the carb on the bottom side of the manifold. Vac leaks can also be internal. A leaking valve may pass a compression check just fine but will only show the leak when running or via a proper leak-down test. The valves spin when running and they will sometimes seat properly but once they spin 180 degrees they leak against the seat.
Lastly, a leak at the header can cause some popping and will eventually burn a valve. If this were the issue you likely would have noticed the exhaust leak by now.
My $.02 for now.
Have you looked to see if the motor is well grounded?
I was about to say the same thing. Grounds can change over time and cause all sorts of fun. Pull them, clean them. Also if your pulling plug wires and some make a difference and some don’t, that seems to point to electrical along with the other symptoms you’re describing. I don’t know the Toyota ignition, but is the coil good? Check all your plug wires real closely, ohm them out with a multimeter. Check your ignition connections, make sure there’s no loose wires, alternator putting out good voltage, etc.
I was thinking along these lines. I know a carb will distribute the fuel across the manifold and he's tried different carbs. I can say I'm sure it's not a fuel injector.😁
