did any of you check out the hot spring ?
Yep. There's whats left of a fiberglass hot tub submerged in the ground being filled by the hot spring. No way to drain this one, it just runs off the top and isn't nearly as inviting as the old one.
Is there a hotspring by Sheeps Crossing? I thought the only one around was up by Childs?
yes, it is slightly north of the bridge at the south of the sandbank towards the western riverbank
when I was there last, it was right by the river - since the banks were so overgrown, you had to wade through the river to get to it
on KingBee's upright pic of the bridge, you see the sandbank, and a bushy tree to the left in the direction that the white 4-runner is pointing - that's where the hot spring is, right under that tree
since the hot water was flowing into the river continuously, I wouldn't be as concerned with contamination as I would be at Childs
The one in childs is contaminated from other human caused things....![]()
I remember a foot path through the reeds to get in there but never checked it out.
only long-term solution is to keep the idiots out![]()
EWWWWWWW! that is GROSS!![]()
sounds like the trash won over
BTW, if anyone wanted to clean up the hot spring tubs: scoop out the garbage - pour in the bleach; wait a day, may have to repeat........
I was bein sarcastic...... last time I was at the Childs tub, (3 years ago?) it wasn't too bad. the peeps that were there were um, under dressed however.....
Uder dressed is in the eye of the beholder....! Although I guess it would depend on the vintage / model of the Peeps!
last time I was at the Childs tub.......the peeps that were there were um, under dressed however.....
- God bless him) Vince van Horn - believe me, he was a genius with a canoe
