Shackle reversal help
Since there aer a few types out there, specifics may help out with this...
I am kind of new at this this being my first cruiser but was told it may give you about 1.5" more of lift with 4" springs not sure what you are asking please help
Thanks
woody said:
the question is, what are you trying to fix/do?
Make a trail rig for the swamps of Florida and try to run 35" tires with out cutting the body
Thanks for asking help
shackle reversal will give you room for 33's....same as a much cheaper shackle-only lift will....and rear fender cutting will still be required unless you run a 9.5 or 10.5 tire (neither of which is much for swamp use...)
35's are gonna take either a sawzall, big bumpstops, or 4" spring lift.
I wanted to get a 4"lift thats when i was told a shackle reversal would give it another 1.5"'s of lift along with it
Thanks
aaahhh...doubling up....that works...but...
you can get the same lift for less with only longer shackles, BUT will more than likely have on-road steering issues.
IMO, do the 4" lift first, and see what fits/hits. You may find some bumpstops in front and some longer shackles and bumps in rear cover ya fine.
