Just had the bushings and shackles replaced. I don't remember the angle of the shackles not matching. Is this correct?
I just recently installed anti inversion shackles and all have the same angle, or so close you don't notice any real difference. Providing you are setting on level ground and a blanced load; I would suggest a problem might exist with a bent leaf spring. Did the problem exist with the old shackle set up? How much height did the new shackle add?Just had the bushings and shackles replaced. I don't remember the angle of the shackles not matching. Is this correct?
