Well, the a/c saga continues. I don't know what to do with that so I am moving on to other areas that need attention.
1. There is a minor exhaust leak. Appears to be a two piece exhaust manifold? How hard is this?
2. I don't know exactly what this is. I have what I would consider a mild bucking from the engine under cruising conditions. Not acceleration, not coasting with it in gear. Like when you are barely giving it enough gas to maintain the speed you want to go...Any thoughts?
3. Rear wheel seal. I am sure I can do this, but how long should I expect it to take? I have done it on a few Danas but never a Toyota...
4. Drivers seat, carpet. Anyone think it's possible to find the original fabric for thes seats? How about carpet sets?
5. I notice that my carb fan does not run. Haven't heard it anyway in a week of driving...Probably need to look at that as well.
It isn't as bad as it sounds. I don't think most people would even mess with the bucking thing. I am not sure that it may be a easy fix? Would you suggest EGR or perhaps a lean condition in the carb when cruising? Don't know what to do exactly. There appears to be quite a maze of vacuum lines and crap over there above the exhaust manifold. Feels like it leaking between the two manifolds...Not sure if there are two, but there are no leaks at the donut or against the block. I can feel it kind of under the carb...thanks, bryan
