- Year
- 1994
- Vehicle Model
- 80 Series
- Mileage
- 225000
- Color
- Blue
Checking if anyone is interested in trading their 62 series for a built up and extremely well running 94 FZJ80 with fresh head work done by Torfab last year. Engine hums and idles perfectly and have driven it 1500 miles straight without stopping through some hot weather without skipping a beat. It's only been lightly taken off road mostly on washboards for camping purposes. Rust free. Non locked. Paint is aging a little with minor small dings, interior is cloth and in great condition. Looking to trade because I have another 80 have always loved 60s.
Below is the work done a year 1 year ago.
Mechanicals
Steering
Drivetrain
Suspension and Wheels
Brakes:
Additional Metal
Recovery
Lighting
Apple CarPlay head unit
Mechanicals
- Complete head gasket and machining of head, internals and rebuilt of top end by Torfab
- Injector restoration
- All new OEM hoses
- New OEM radiator
- New OEM shroud
- New OEM battery
- New OEM V belts
- New OEM AC belt
- New OEM spark plug wires
- New OEM spark plugs
- New o2 sensors, EGR and PAIR delete
- New OEM downpipes
- New exhaust 2.5” piping and Y pipe
- New Walker catalytic converters (2)
- New Walker silent muffler
- Every bolt and nut turned replaced with New OEM
Steering
- New OEM steering gear mounting bolts
- New OEM low pressure power steering lines
- New OEM high pressure power steering lines
- Marlin Crawler HD tie rod with zinc lock nut
- Marlin Crawler HD drag link with zinc lock nut
- 555 tie rod ends
- All New OEM bolts and crown nuts
Drivetrain
- New OEM front axle seals
- New OEM front bearings
- New OEM front trunnion bearings
- New OEM rear axle seals
- New RCV Ultimate 300m rear axle shaft
- Drive shaft seals
- Icon stage 1 variable rate springs 3” lift
- Icon stage 1 2.0 rebuildable aluminum shocks
- HD adjustable front pan hard with zinc lock nut
- HD adjustable rear pan hard with zinc lock nut
- Metal Tech adjustable lower control arm
- Metal Tech adjustable upper control arm
- Icon caster bushings - drives solid at high speed
- Delta rear pan hard lift
- Whiteline HD rear sway bar
- LCP zinc rear sway bar drop
- 17x8.5 Method 316 in Matte Black include full spare
- 315x70x17 Nitto Trail Grapplers
- 1.25 wheel spacers
Brakes:
- Powerstop slotted z36 rotors front and rear
- Powerstop pads
- Icon extended brake lines
Additional Metal
- Metal tech sliders
- ARB front bumper
- 4x4 Labs base rear bumper with 3 jerry can holder and rear spare mounts and hidden hitch + ladder
- Prinsu roof rack
Recovery
- Warn EVO 10-S synthetic rope winch wireless or wired control
- Factor 55 offset fairlead
- Factor 55 closed system winch shackle
Lighting
- LED low beam
- LED high beam
- LED parking lights rear and front
- LED turn signals rear and front
